Does anyone know how to do the SCTheme example with Buttons/Textboxes?
Theme changes works by doing a different style. If you for your button and text box create your own style the Smart Client theme change shouldn’t overwrite it.
i do have an own style. It still overwrites it. But still thanks for the answer.
You are right that it wasn’t that simple. I have had to consult a Milestone Developer. Here is a XAML snippet that works and does not get overwritten by the theming.
<Button>
<Button.ContentTemplate>
<DataTemplate>
<TextBlock Foreground="Yellow" Text="Button text"/>
</DataTemplate>
</Button.ContentTemplate>
</Button>
Note that we recommend to use “XProtect Design System user controls” as mentioned here..
https://productexperience.milestonesys.com/
These are themed. They are recommended as it makes it easy to get a design that is very close to that of the Smart Client itself. You might not want this, but instead follow your own design style, but I thought I should mention it.
Thanks for the Answer.
Helped alot. Its a little different for Textboxes but nearly the same.
If someone wants to use it with Textboxes: use a ControlTemplate instead of a ContentTemplate.
