How to use connectWithId without disabling CHAPS security ?
I would like to use connectWithId to restore a connection after a navigation but I have not find how to make it work without disabling CHAPS using the following code :
XPMobileSDKSettings.supportsCHAP = false
Can I have an example code or an explanation on how to make it work with CHAPS enabled.
Hi Denis,
I don’t believe “connectWithId” was designed with that possibility in mind (usage of Chap).
And to be honest all the tricks in the protocol as DHKE, CHAP support, commands / parameters encryption, etc could only provide anti-sniffing protection.
But non of them could handle man-in-the-middle attack for example.
My point is that you have to configure HTTPS in the Mobile server and could disable CHAP support without any further worries.
Hi Petar,
Thank you for the reply. I will do that and rely on HTTPS.
