I get the below error:
i got the above error when i log into XProtect Management Client 2017 R3.
https://force.milestonesys.com/support/MccSupportCommunity
This is an Exception from VideoOS.Platform.dll, does the install use the dll as it comes with Corporate, or has it been updated?
yes
Can you explain how we can re-create the issue?
What plugin’s do you have in the different MIPPlugin folders?
