Hi David,
If you’re running “C-code” software (Corporate, Expert, or a “plus” product version) then you can use MilestonePSTools to get the hardware passwords.
Install-Module MilestonePSTools
Connect-ManagementServer
Get-Hardware | Get-HardwarePassword
If you’re running “E-code” I’ve written a tool to decrypt credentials from the Configuration.xml located in [C:\ProgramData\Milestone\Milestone](file:C:/ProgramData/Milestone/Milestone) Surveillance\
http://download.milestonesys.com/jh/XppPwdDecoder.exe
Cheers,
Josh
