Icon click borders is being changed on "Setup" click.
Hey all,
We have this item called “lamp” with a mapicon set.
on its own, the icon is clickable once entered each one of his borders(top, left etc…)
After clicking on the “Setup” button, the item become clickable from just a one element in the image.
Changing the icon back to “on” and “off” would reset this behavior up until the next “Setup” click.
the icon contains all 6 resolutions.
Can you please tell us which product and version of the XProtect VMS you use? Which version of the MIP SDK are you using?
Yes, there both are 2020 R1.
Milestone Development will start an investigation.
Could you please shed some light on how to specifically reproduce this type of issue?
We’ve tried to create a local reproduction, but we can’t seem to find the exact element for this scenario.
The bulb element seems to be a different one, it is your custom element, isn’t it?
Considering the behavior this should be related to some sort of resizing/framing of the element when in setup mode.
Can you please provide us the bulb plugin for further investigation?
