I developed as a component sample.
Use an ‘ImageViewerControl’ class .
But ‘ImageDisplayedEvent’ is not working.
How can I use ?
How can I use ?
Just did the experiement and tried it myself. I do not see a ImageDisplayedEvent either.
Thank you for quick response.
If so, is there another way to know the status of the live stream in ImageViewerControl?
I would like to know when the stream is stopped.
I tried using “LiveStreamInformationEvent”.
But has not been consistently calling .
If the stream stop so does “LiveStreamInformationEvent”. You might be able to use the methods in the StatusViewer sample to get camera failures etc.
Thank you very much.
I hope “ImageDisplayedEvent” implemented at any later time.
Have a nice day.
It will be in the MIP SDK 2017 R1..
Developer comment: Implemented the ImageDisplayedEvent as it is in the Smart Client. It also provides information about the image being displayed (size etc)..
Thank you very much. Bo. ![]()
