Inconsistent video stream through ONVIF device manager
I am using VPC to access the a Milestone camera stream through the RTSP URL provided by the ONVIF Device Manager. The video stream is very weak and inconsistent. However when viewing the same video through the Milestone UI the video is fine so there is not an issue with the video source. Any ideas on what could be causing this or any ideas on how to troubleshoot the issue?
Dear Tim,
We can recommend to try switching the transport from TCP to UDP or vice versa and check if there is any difference.
If you continue to experience the issue, it will be best to contact our support.
