To use either “Alarm Preview” or “Alarm List” in my plugin, I assume they go inside of myPluginViewItemWpfUserControl. Is that the right starting point? SDK samples did not help yet. Maybe I missed something. What are the basics of putting either AlarmPreview or AlarmList inside myPluginViewItemUserControl or anywhere in myPlugin?
You can, controlled from your plugin, insert the “Alarm Preview” or “Alarm List” in a view. This can be done using the InsertBuiltinViewItem method, you can see this done if you explore the Smart Client View and Window tool plugin sample, the View Control tab.
