I have to insert a playback control on a position of a view (index of ViewAndLayoutItem). Which user control do I have to use and how do I insert it into an existing view? The user shall not be able to control the playback (the playback is totally controlled by some background logic in the plugin). In the SCInsertCamera sample I saw how a camera is inserted on a position of a view. Now I have to to do the same for playback.
There is a sample called Smart Client Camera Playback Control might be helpful for you. This sample is newly released so you will find it in 2021 R1 SDK.
