InsertBuiltInViewItem: What param needed to change stream ID?
Hi Eric,
You should add a property named “StreamId” with the GUID of the stream as the value.
/Peter
Hi Peter,
Thank you for your answer, I did not ask the question properly. How can I get the GUID of the different streams? I only need streams 1 and 2 specifically for the x16 and x64 universal drivers?
Hi Eric,
The PlaybackUser component sample shows how to get them:
           var streamDataSource = new StreamDataSource(\_selectItem1);
           \_streams = streamDataSource.GetTypes();
/Peter
Hi Peter,
Thanks allot. I needed to test the stream ID with the MediaLiveViewer sample and it works great.
/Eric
