I am new on Milestone Platform and there is a lot of documentation to use. I need some info about how to inject into Milestone alarms from external device.
Actually my device support Modbus and SNMP and I have also both connectors in C#, but I can use also C++.
As far I understood should be possible to inject events/alarms to Milestone platform, is it right ?
I Installed Milestone and SDK and I am trying to interface Event Server, and I should send alarm through Event Server.
To be clear: I have event for alarm ON and Alarm OFF so I suppose to create two events (analytics one) and combine both to manage an alarm. Am I right ? or I have to use different configuration ?
Once alarm is active on Milestone I have to connect camera and maybe set a specific preposition.
Francesco
Thanks very much for the doc. Let me test it and I’ll back to you.
Thanks again
Francesco
Something is working, I mean. I am using XProtect+ and i was missing some right configuration, and after reading your pdf now seems better, now I am able to send event on event server and this is great job (log show that events are received). Thanks Bo.
Next step.
- I am not able to see on Smart Client Alarm Viewer, maybe I am missing some pkg.
- I configured alarm but I dont see alarm generated by event (maybe configuration is wrong)
- PLC send event when alarm is OPEN and later different one when it is CLEARED. Not clear to me how to combine them to open and then clear alarm on Milestone, is it possible?
Thanks for your support
Francesco
Whereas XProtect Esssential+ is free XProtect Express+ is not.
Milestone partners can get test licenses, to explore the options for Milestone Solution Partners please see - https://www.milestonesys.com/community/become-a-partner/solution-partner/
