Integration Milestone in Java Aplication.
Hello all,
I wonder what the best solution to integrate the Milestone a java application.
I need to integrate Video Live, Recorded Video, List of Devices(Cameras and I/O’s), List of Events(Alarms), Control input’s output’s.
You can suggest me some information about the best solution for make this solution ?
Thanks for your attention best Regards Luis Oliveira
Unfortunately there is no Java Application sample in the MIP SDK. Try to explore the ImageViewer ActiveX Jscript, the sample uses an ActiveX to display images from the Milestone system, I hope you can use activeX.
