Buenas, tenemos la versión Milestone Xprotect Corporate 2016 R3, pudimos seguir todos los pasos de la integración del Axis Perimeter Defender, los eventos llegan perfecto al Gestor de Alarmas, pero no logramos que ver el Metadata tanto en el vivo como en el recording.
El driver del MIP lo pudimos agregar, está grabando y aparecen los 1 y 0 arriba.
La versio del APD es la 1.2.1.30142.
La versión del Plugins es 1.1.3
Gracias, saludos
Axis Perimeter Defender is supported by Axis.
Developing integrations is the primary subject for this developer forum while getting an integration that is finished / developed is not, I think you are asking in the wrong place. I hope you find it constructive when I advise you to ask elsewhere. Try asking Axis support. Perhaps Milestone Support Community will be an alternative source of help also.
Hi Bo! Fixed issue. When installing the Spanish version of Milestone, rename the metadata driver. To avoid collision metadata sources, the add-in only uses fonts that have “MIP Driver” in their name. So we put the name of the metadata in English and started working correctly. Thank you very much. regards
