internal SystemInfo
It seems now (MIP SDK 2019R3) that SystemInfo is internal, before it was public.
What do you suggest to replace it?
Best regards,
SystemInfo was actually public against the intentions of Milestone and it was then turned internal a year ago.
Dependent on what you need the VideoOS.Platform.Configuration Class might be the class to use instead.
https://doc.developer.milestonesys.com/html/index.html?base=miphelp/class_video_o_s_1_1_platform_1_1_configuration.html&tree=tree_search.html?search=configuration
Which information/data is needed for you? Can you tell us specifically what information you use? We might be able to tell you alternative ways to get the same information.
Ok, we will see that.
Thanks,
