"Invalid Alarm error"- when using the Add method in AlarmCommandToken Interface
I am constantly getting an “invalid alarm error” with the Add method of AlarmCommandToken API when pushing an alarm to the management client using the API.
Here is my SOAP message which I am sending:
<soapenv:Envelope xmlns:soapenv=“http://schemas.xmlsoap.org/soap/envelope/” xmlns:cen=“http://videoos.net/2/CentralServerAlarmCommand” xmlns:urn=“urn:milestone-systems”>
soapenv:Header/
soapenv:Body
cen:Add
 <!--Optional:-->
 <cen:token>TOKEN#014b743c-5ce9-42d9-800e-e4528e554eb8#[win-79sljaanr8l.in.idemia.com//ServerConnector#</cen:token>](http://win-79sljaanr8l.in.idemia.com//ServerConnector#%3C/cen:token%3E "http://win-79sljaanr8l.in.idemia.com//ServerConnector#%3C/cen:token%3E")
 <!--Optional:-->
 <cen:alarm>
  <urn:EventHeader>
    <urn:ID>00000000-0000-0000-0000-000000000000</urn:ID>
    <urn:Timestamp>2021-02-04T10:00:00.000Z</urn:Timestamp>
    <!--Optional:-->
    <urn:Priority>1</urn:Priority>
    <!--Optional:-->
    <urn:PriorityName>High</urn:PriorityName>
    <!--Optional:-->
    <urn:Name>External Event</urn:Name>
    <!--Optional:-->
    <urn:Source>
     <urn:FQID>
       <!--Optional:-->
       <urn:ServerId>
        <!--Optional:-->
        <urn:Hostname>localhost</urn:Hostname>
       </urn:ServerId>
       <!--Optional:-->
       <urn:ObjectId>52c65d53-e611-4875-ba2d-d8cd5017ea84</urn:ObjectId>
     </urn:FQID>
    </urn:Source>
  </urn:EventHeader>
  <!--Optional:-->
  <urn:State>1</urn:State>
  <!--Optional:-->
  <urn:StateName>New</urn:StateName>
  <!--Optional:-->
  <urn:Category>2</urn:Category>
  <!--Optional:-->
  <urn:CategoryName>Critical</urn:CategoryName>
  <!--Optional:-->
  <urn:Count>1</urn:Count>
 </cen:alarm>
</cen:Add>
</soapenv:Body>
</soapenv:Envelope>
The alarm category is already defined in management client. I have also tried various other options without succcess. Is there any documentation, on which fields are mandatory? Also, Am I doing anything wrong (like missing any important fields) ?
Here is the SOAP response I get:
<s:Envelope xmlns:s=“http://schemas.xmlsoap.org/soap/envelope/”>
<s:Body>
<s:Fault>
 <faultcode>s:Client</faultcode>
 <faultstring>Unhandled exception: System.ArgumentException: Invalid alarm
at VideoOS.Event.Server.Event.RuleEngine.ProcessAlarm(Alarm alarm)
at VideoOS.Event.Server.WebService.Alarm.AlarmCommandToken.Add(String token, Alarm alarm)
 <detail>
  <AlarmServiceFault xmlns="[http://schemas.datacontract.org/2004/07/VideoOS.Platform.Proxy.Alarm](http://schemas.datacontract.org/2004/07/VideoOS.Platform.Proxy.Alarm)" xmlns:i="[http://www.w3.org/2001/XMLSchema-instance](http://www.w3.org/2001/XMLSchema-instance)">
    <ErrorDescription>Unhandled exception: System.ArgumentException: Invalid alarm
    <ErrorReason>Unknown</ErrorReason>
  </AlarmServiceFault>
 </detail>
</s:Fault>
</s:Body>
</s:Envelope>
Can you please check if there are errors or information in Event server logs?
Event server log is “[C:\ProgramData\Milestone\XProtect](file:C:/ProgramData/Milestone/XProtect) Event Server\logs”.
@Rie Kiuchi (Milestone Systems)​ Event server doesn’t give any more details either. It says:
2021-02-11 9:06:53 PM UTC+05:30 Error AlarmCommandToken Unhandled exception in web service with message: Invalid alarm
Exception details:
Unfortunately there is no protocol sample but can you please try to test this sample and see if it works for you?
https://doc.developer.milestonesys.com/html/index.html?base=samples/libraryeventgenerator_sample.html&tree=tree_2.html
If this sample does not work unmodified, we must suspect there is a general error to the XProtect VMS and your code might be correct.
