Is it possible to change the behavior of the export button of playback display?
I want to display its own export screen instead of the existing export screen.
Please tell me how to do it if possible.
Thank you.
Thank you.
It is possible to do export work as the Smart Client Export plugin sample shows. It is not possible to modify the behaviour of the export button in playback mode or modify the built-in export dialog of the Smart Client.
Thank you for your reply.
Consider another way.
