Is it possible to configure the video buffer size using Xprotect API?
Our development department is in the stage of feasibility tests before the implementation of our development in our Command and Control Software so that it will be possible to display the bounding Boxes and the trace on the object in the our Command and Control Software as it is done in Milestone from analytics systems such as Avigilon or others.
• We have an implementation using ImageViewerControl for presenting video, and would like to delay its presentation in up to 1 or 2 seconds.
• XProtect SmartClient provides a field for configuring the video buffer size, and it seems to do the job
• Is there a similar property in Xprotect API, for acheiving this?
I think you can use
VideoOS.Platform.Client.ImageViewerControl.SetVideoQuality
Ref.
https://doc.developer.milestonesys.com/html/index.html?base=miphelp/class_video_o_s_1_1_platform_1_1_client_1_1_image_viewer_control.html&tree=tree_search.html?search=imageviewercontrol
