Is it possible to export processed images with the standard export function?
Is it possible to export processed images with the standard export function? ​
I want to output a picture with a figure attached.
If possible please tell me how to do it.
Thank you.
No.
It would be possible to develop a plugin that is exported and takes data with it for export in the Milestone format.
The DataExport plugin sample might be a useful starting point.
https://doc.developer.milestonesys.com/html/index.html?base=samples/dataexport.html&tree=tree_1.html
Thank you for your reply.
I acquired the frame sequentially and implemented it to process it.
