Is it possible to retrieve a camera's microphone audio from the Mobile Server protocol?
We would like to stop using the ImageViewer / EngineManager / AudioPlayer ActiveX components from our application and start using the Mobile Server protocol. Is it possible to retrieve a camera’s microphone audio from the Mobile Server protocol?
Thanks,
Daniel
Yes.
There is even an audio sample.. See it here: https://doc.developer.milestonesys.com/mipsdkmobile/index.html?base=samples/Web_AudioSample.html&tree=tree_5.html
Hi Bo, thanks for the answer. The page you linked tells me the audio sample should be found at the following path in the Mobile SDK :\XPMobileSdk\Web\Samples\Audio.
However, when downloading the Mobile SDK, I can’t find the Audio folder in the Samples directory. Is there another way of getting the sample?
Thanks,
Daniel
Yes.
MIPSDKMobile_2019R1.zip - \Web\Samples\Audio
You might have unzipped it somewhere else..
Hi Bo,
My bad, I used the XPMobileSdk.zip linked in the SDK documentations here : https://doc.developer.milestonesys.com/mipsdkmobile/ which (at this current time) did not have the specified folder.
I was able to download the MIPSDKMobile_2019R1.zip from the SDK page (not from the SDK documentation) and find the sample.
Thanks!
That the documentation includes a link to a download that is not updated to newest version is not ideal. I have made a request to the right people in Milestone to make a correction to this. Thank you for raising my awareness to this issue..
