MessageCommunication.TransmitMessage() does not provide message-level encryption.
MIP Message Communication routes messages through the Event Server. When secure communication with certificates is enabled in Milestone XProtect®, the supported underlying communication is protected by HTTPS/TLS. If secure communication is not enabled, you should not consider messages encrypted in transit.
You therefore do not normally need to encrypt Message.Data yourself solely because you are using TransmitMessage, provided XProtect is configured for secure communication.
If you need encryption that is independent of the XProtect transport, you must implement application-level encryption for the message data.
One important distinction: transport encryption protects data while it is in transit. It does not make a message private from other MIP components that legitimately participate in the messaging system, because the Event Server acts as the message router.
