Hi Milestone,
I has successful to send the Analysis event from "Protocol Integration Sample - Analytics Event Trigger via XML and it work smoothly.
But at your sample code, the API is base on HTTP protocol.
By the secure concern, I tend to use HTTPS without HTTP protocol to protect the data when sending to Milestone XProtect Server.
Is Protocol Integration can send the Analysis event base on HTTPS protocol ?
