Currently, I’m using the MilestonePSTool to get the configured camera names from Milestone.
So that process is done Manually. What I need is a way that I can get the detail of a camera when it is configured in the Milestone Management server.
Can you share more detail about what you’re trying to do? I see you’re using MilestonePSTools to get information from Milestone already, so what is it you need exactly?
Are you saying you want to avoid using MIP SDK / PowerShell and extract the information from the Management Client instead?
What i need is to receive a notification or an event when a new camera is configured in the Milestone with camera name (Milestone Camera Name).
Currently we have to run the MilestonePSTool manually to get the data.
