is there a way to display direct streaming video in web application using SDK
Following this link :
https://doc.milestonesys.com/latest/en-US/standard_features/sf_webc/webc_directstreamingexplained.htm
It seems that direct streaming allows to display video in the Webclient.
Is it possible to achieve the same functionnality using SDK? Are there some documentations about this ?
Hi
You can have a look at this client sample on GitHub to see how Direct streaming can be utilized.
This video contains an explanation on how to run the sample.
Br,
Nikolay
Yes. There is a sample about this. The samples are part of the Mobile Server.
How to run or host in another app you can find here :
https://doc.developer.milestonesys.com/mipsdkmobile/samples/HostOnServer_5.html
