Hi, I have been looking for a way to export certain video from the milestone server to a specific path in the linux OS; however I have only found MIP SDK but as far as I understood it can’t be adapted to a linux environment. Do you know if there is any other way to do this?
There is an Exporter class in the MIP Library, but as this is a .Net Framework library, you are unfortunately right, it will not work for you in the linux OS.
The workaround is to use the Mobile Server and Mobile SDK. You can create an export package in the Mobile Server and download it.
This thread might be the best guide to do this using Mobile.. https://developer.milestonesys.com/s/question/0D53X0000D0MC7lSQG/how-to-export-playback-using-mobilesdkdll-in-wpf
General documentation for Mobile SDK.. https://doc.developer.milestonesys.com/mipsdkmobile/
