Using Xprotexct Smart Client 2016 R3
There is no functionality for time lapse video export in the Smart Client.
Using the export methods of the MIP SDK the answer is the same; the functionality is not there.
A possible workaround if developing an integration would be to extract JPEG images with the JPEGVideoSource, then using methods outside the MIP SDK generate an AVI or similar from the JPEGS.
