Is there any way to make Home button to activate Default preset, what is made default in management system?
There is a ton’s of cameras what react to different ways to Home button in client. I know for Bosch driver you could select Home preset from driver, but for Onvif and others, there is no such option. I see no point or little point of making default position if it’s not linked to Home button in client. There is suggested solution to add separate “Home” button in a Client for a view, but if I use SmartWall or just using cameras from search etc, then there won’t be buttons what will do that. Also if I have tons of views then, its a lot of work to add these buttons you know.
If it messes up something, then it would be lovely, if other camera drivers with PTZ function could have the same option to choose which preset will be the “Home”
