Issue while calling goToTime Function in VideoPlayback
var playbackController;
function buildTopBar(controller) {
var topBar = document.querySelector('.bottombar.topbar');
var playBackButton = topBar.querySelector('.playBackButton');
var playForwardButton = topBar.querySelector('.playForwardButton');
playBackButton.addEventListener('click', controller.playBackwardTrigger);
playForwardButton.addEventListener('click', controller.playForwardTrigger);
topBar.style.display = 'block';
function startCameras() {
var cameras = document.getElementsByClassName('camera');
var event = new Event('click');
for (var a = 0; a < cameras.length; a++) {
  cameras\[a\].dispatchEvent(event);
function Controls(playbackControllerId) {
this.play = function (speed) {
  XPMobileSDK.changeMultipleStreams({
    PlaybackControllerId: playbackControllerId,
    Speed: typeof speed == 'number' ? speed : 1
  }, function (parameters) { });
this.pause = function () {
  this.play(0);
this.goToTime = function (timestamp) {
    SeekType: 'Time',
    Time: timestamp
function Controller() {
var id;
var videoConnection;
var playbackSpeed = 0;
var controls;
var self = this;
function createPlaybackControllerCallback(connection) {
  var connectionResponse = connection.response;
  videoConnection = connection;
  id = connection.response.parameters.PlaybackControllerId;
  var videoConnectionObserver = {
    videoConnectionReceivedFrame: onReceivedFrame,
    videoConnectionTemporaryDown: function () { },
    videoConnectionRecovered: function () { },
    videoConnectionNotAvailable: function () { }
  videoConnection.addObserver(videoConnectionObserver);
  if (videoConnection.getState() == XPMobileSDK.library.VideoConnectionState.notOpened) {
    videoConnection.open();
  controls = new Controls(id);
  buildTopBar(self);
  startCameras();
document.getElementById('dropdown-list').addEventListener('change', function () {
  // Create a new playback controller when the dropdown value changes
  createPlaybackController();
function createPlaybackController() {
  // Convert the ISO timestamp to milliseconds since the epoch
  var initialTimestamp = Date.parse('2023-11-28T06:58:42.327Z');
  XPMobileSDK.createPlaybackController(
      SeekType: 'Time',
      Time: initialTimestamp
    createPlaybackControllerCallback,
    function (error) {}
var timeStamp;
function onReceivedFrame(frame) {
  if (frame.hasPlaybackInformation) {
    onPlaybackEvents(frame.currentPlaybackEvents);
  timeStamp = frame.timestamp;
  updateTime(frame.timestamp);
function onPlaybackEvents(playbackEvents) {
  if (playbackEvents & XPMobileSDK.library.ItemHeaderParser.PlaybackFlags.Stopped) {
    // onPlaybackStopped();
  if (playbackEvents & XPMobileSDK.library.ItemHeaderParser.PlaybackFlags.Forward) {
    // onPlaybackForward();
  if (playbackEvents & XPMobileSDK.library.ItemHeaderParser.PlaybackFlags.Backward) {
    // onPlaybackBackwards();
* Updates time element
function updateTime(timestamp) {
  playbackTimestamp = timestamp;
  var date = new Date(timestamp);
  var hours = date.getUTCHours();
  var minutes = ('0' + date.getUTCMinutes()).slice(-2);
  var seconds = ('0' + date.getUTCSeconds()).slice(-2);
  var formattedTime = hours + ':' + minutes + ':' + seconds;
  document.querySelector('.topbar .playTimeIndex').innerHTML = formattedTime;
* Change video speed
function playbackChangeSpeed(speed) {
  if (!videoConnection || speed == playbackSpeed) return;
  speed = Math.round(speed);
  controls.play(speed);
  if (speed == 0) {
    playbackSpeed = 0;
  else if (speed < 0) {
    playbackSpeed = -1;
  else if (speed > 0) {
    playbackSpeed = 1;
  updatePlaybackButtons();
I have a button in UI on click of that I tried to call the goToTime() Function but I’m facing the error at self.getId = function () { return id; } ID not found
Hi, Abhijeet,
I miss some of the context on how you try to execute the sample but there are a lot of functions that are missing,
For example, you can see this link: https://github.com/milestonesys/mipsdkmobile-web/blob/main/Samples/MultiCameraPlayback/js/sample.js#L211 where it explains how to use go to time with multi-camera playback.
Best regards,
Asen Bozhilov
