Hi everyone,
I’m testing the Milestone WebRTC sample from GitHub and am having issues connecting to the camera. The connection seems to establish initially but then disconnects shortly after. Below are the logs from the diagnostic output:
Diagnostics log
Signaling state: have-remote-offer
Signaling state: stable
ICE gathering state: gathering
ICE connection state: checking
Connection state: connecting
ICE connection state: connected
ICE gathering state: complete
Connection state: connected
Establishing connection time: 2690 ms
ICE connection state: disconnected
Connection state: disconnected
Connection state: failed
The first idea is to check whether the camera is using h.264. Other codecs cannot be used. (Will be in future versions.) Either the camera cannot give h264 or isn’t configured to do so.
Verify that the camera streams if you test with Smart Client and that the setup is h.264.
If that is not it, please, as next step, see if the log at “[C:\ProgramData\Milestone\XProtect](file:C:/ProgramData/Milestone/XProtect) API Gateway\Logs\gateway.log” includes some information that might pertain to this.
If this doesn’t solve it, please include some information about the XProtect product and version, and some information about camera (make, model, firmware version). Also, are you using the newest version of the sample? - https://github.com/milestonesys
