We observed different behavior in an earlier version of XProtect < 2023 r1 where changing the mode live/playback on a floating window affects the plugin live video on the main window.
We have used server carrousel, video preview, and message tester to check the behavior.
We have attached the XProtect SmartClient version and videos for your reference.
We expect the latest XProtect version behavior to be correct. When we change the mode from live to playback on the floating window, the main client Windows plugins should remain in live and wise verse.
I will need to reproduce the issue in order to report it as a bug, or by reproducing it I might realize a solution.
Can you please make a step by step description how I can, in the easiest way, reproduce the issue in a Smart Client 2022R3 using one or more MIP SDK samples?
Just use the server carrousel plugin in a view and open a floating window with the same view. Now change the mode from live to playback on the floating window, the main window sever carrousel plugin also changes the mode.
Thank you for the clarification. I have now reproduced the issue and made a report with Milestone Development. I will keep you informed about our progress towards finding a fix.
