Hi, has the knowledge base been removed or has user access changed? I am unable to access anything on https://support.milestonesys.com/support/general-support-cases
There has been some changes to this but this link should still work.
Please try again using the link, if that doesn’t work..
Try the following steps instead:
Log in, then select XProtect. From there, you will have access to the Packs and the Support section.
In the menu, choose the support option you need.
