Login Status
Hello team,
I have a client application that should try automatic re-logins whenever it is logged out by the server. Is there a method to be notified when the client is logged-out for any reason? I am not sure it’s relevant but I am using component integration
For MultiUserEnvironment I am using this:
public bool IsLoggedIn(Uri server)
  return \_context.Configuration.ServerFQID != null &&
    MultiUserEnvironment.IsLoggedIn(\_context, server);
Where _context is the UserContext for the user. You can also use it for Environment (ie, single-user environment), it has the IsLoggedIn() method as well.
Both clauses of my return statement are probably overkill but it works!
You can, of course, put this in a loop on a background thread to monitor for logged-in status.
