I’m trying to find out which event is raised when a user presses a “Manual recording start/end” in the client.
I want to handle the event with a c# code with the sdk.
I did not found any example in the ComponentSamples
This is one of the situations where the answer depends on the XProtect product you are using.
You can see this event if you use the StatusViewer sample (uses NewEventIndications) if you are using XProtect Corporate, Expert, Professional+, Express+ or Essential+.
There is no easy way to do this if using XProtect Enterprise, Professional, Express.
I’m using XProtect Corporate 10.2.B.
I’m checking the example you suggested
