I attempted to set up a background service that listens to MetadataLiveSource, but it does not function when I use it within the EnvironmentType.Service. However, it works when I use EnvironmentType.Administration. Is there a workaround for this issue, or am I overlooking something?
Not sure if this is a timing issue since EnvironmentType.Service is within the Event Server. Is there a way to determine when the event server has fully finished loading?
public override void Init()
_stop = false;
_thread = new Thread(new ThreadStart(Run));
_thread.Name = "MetadataPlugin Background Thread";
_thread.Start();
void _messageCommunication_ConnectionStateChangedEvent(object sender, EventArgs e)
if (_messageCommunication.IsConnected && !commReady)
try
if (_alarmClient == null)
_alarmClient = _alarmClientManager.GetAlarmClient(EnvironmentManager.Instance.MasterSite.ServerId);
if (_metadataLiveSources.Count == 0)
IList<Item> metadataItems = _metadataService.GetMetadataItems();
if (metadataItems != null && metadataItems.Count > 0)
foreach (Item item in metadataItems)
MetadataLiveSource metadataLiveSource = new MetadataLiveSource(item);
try
metadataLiveSource.LiveModeStart = true;
metadataLiveSource.Init();
metadataLiveSource.LiveContentEvent += OnLiveContentEvent;
_metadataLiveSources.Add(metadataLiveSource);
_liveSourceToItem[metadataLiveSource] = item;
catch (Exception ex)
EnvironmentManager.Instance.Log(false, "MetadataPlugin", $"Error initializing AlarmClient or MetadataLiveSources: {ex}", null);
finally
commReady = true;
EnvironmentManager.Instance.Log(false, "MetadataPlugin", "Communication is ready", null);
private void Run()
EnvironmentManager.Instance.Log(false, "MetadataPlugin background thread", "Now starting...", null);
_messageCommunication = MessageCommunicationManager.Get(EnvironmentManager.Instance.MasterSite.ServerId);
_messageCommunication.ConnectionStateChangedEvent += new
EventHandler(_messageCommunication_ConnectionStateChangedEvent);
while (!_stop)
Thread.Sleep(2000);
EnvironmentManager.Instance.Log(false, "MetadataPlugin background thread", "Now stopping...", null);
_thread = null;
/// <summary>
/// Define in what Environments the current background task should be started.
/// </summary>
public override List<EnvironmentType> TargetEnvironments
get { return new List<EnvironmentType>() { EnvironmentType.Administration }; }
