We are designing a perimeter solution and want to integrated IP cameras and sensor alarms into Milestone system.
IDs sensors offers dry relay contact , is there any possibility to integrate the alarm using dry relay into the milestone syste. Please see block diagram for clarification.
Just a MIlestone XProtect supports cameras it also support Input/Output devices. If you look at the Supported Hardware page in the Milestone web site you can filter on Input/Output devices and see what is readily available.
http://www.milestonesys.com/solution-partners/supported-hardware/other-xprotect-products/
It is possible to use the MIP SDK to do integration if you willing and able to do some programming.
