We are able to view videos from smart client and also through web server page.
Currently we are using Milestone XProtect Expert 2018 R3. however the old system was using Milestone enterprise 6.5 & 2014. it was working fine with both version. The issue is with Milestone XProtect expert 2018 r3.
Our live and recording view integration works with our existing Milestone setup but doesn’t work with the new setup.
(Existing Milestone Versions : Milestone Xprotect Enterprise 6.5d & Milestone Xprotect Enterprise 2014 8.6c / New Milestone Version : Milestone Xprotect 2018 R3)
Are there any Milestone settings that can be adjusted on the new setup to make this work or do we need to change our implementation and what would need to be changed exactly ?
Following are more details on our existing implementation:
The following is part of our Cam-Live-ViaNVR.html used for the integration: - attached png file
This works on our existing milestone with shown URL: - attached png file
But with the new Milestone it gives following error: - attached png file
We also tried changing port nr. to 7563 which gives following error:
- attached png file
Attached the script which is copied from view source of video page - Source.doc
