Not sure if this is the right place for this, I’ll be happy if you could refer me to the right place if not.
We have a requests for improvements for the milestone mobile application.
One, we need to be able to stream video and watch other streams in the same time, I was unable to achieve this option.
two, the stream is only in landscape mode and it is not normal to hold the phone this way, it will be great if it could be change for portrait.
currently we’re using third-party applications, but we want to enjoy the metadata that the milestone application provides.
Thank you for your help.
Thank you for the feedback, Ohad !
We really appreciate it !
I’m a little bit curios, whats is the scenario behind “need to be able to stream video and watch other streams in the same time” ?
I just cannot imagine the use-case
Imagine a policeman that wants to see streams from his team members, he’ll have to stop his stream to do it , then the operator on HQ wont be able to get his stream and metadata.
Another thing, after finishing watching his team members streams he’ll have to start his stream again, this can be complicated while on operation or he even may forget to reactivate the stream.
The stream should be fluent.
On the google play store there are some RTSP applications (such as “RTSP Camera server” and “ip webcam”), I suggest you to review the options on these apps and add some features to your app.
