I’m working a plugin which uses my dll to procces images.
Its working fine when the plugin is in a Client,
However when I want to run it in service(in event server), it says:
"Unable to load DLL… …The specified module could not be found. (Exception from HRESULT: 0x8007007E)@
But i know the DLL is available and the error only appears when i try to use object from an other dll in it. I tried to add all possible dependecy to the plugin folder and even for enviroment path, but still the same error.
What can cause such problem?
