Milestone shows "license invalid" when adding a camera from Component Integration
I am using Component Integration to add a camera into a Milestone XProtect Corporate 2022 R1 system.
It happens to different cameras (brands and models) but only from Component Integration. If I added them from Management Client the camera works just fine, it never show that error and the live video is showed without any problem.
I have this integration running from a long time working with other Milestone versions (2018R3, 2020R2) and never failed.
Could it be possible that something breaks in terms of compatibility with 2022R1 version?
Please let me know if you need more information.
You say you use Component Integration, maybe the methods you use is the same as in the “ConfigAddCameras” sample. Is it?
https://doc.developer.milestonesys.com/html/index.html?base=samples/componentsamples/configaddcameras/readme.html&tree=tree_2.html
If you use this sample unmodified do you see the same issue?
Are you building your integration usinng the newest MIP SDK Nuget? (If no, please try if it makes a difference.)
