This is in regard to the Honeywell Galaxy Dimension integrating with Milestone Xprotect Corporate 2014. As per the instructions mentioned in the Integration document, configured all the steps. But when connecting to the Panel from Milestone Xprotect its says " Failed to read configuration from the box". Please advice to sort this issue ASAP.
Regards,
Ranjith
