Mip plugin access
I have created some plugin which is creating overlay on video .It supports on smart client .Why it is not supporting for external onvif client from onvif bridge.if i want to display the overlay wherever the video go how can i do that? .
Help me on this topic.
The overlays you have implemented is probably on the ImageViewerControl. ImageViewerControl is not used in Onvif client.
You cannot put overlays on the footage on the Onvif Bridge.
A possible workaround is to set up the cameras to make an overlay. The cameras would then stream image with the overlay to the recording server and the Milestone VMS would not know it was there. It will only work if you can set the cameras up to supply this, it is outside the control of the Milestone VMS if you are able to do this.
Ok thanks its helpful.
