Cameras have Description property (see the attached screenshot), how can we get this property using MIP SDK?
Item does not have a separate field called Description and Item.Properties also does not contain it.
Thank you,
Vadym
Thank you,
Vadym
The description property is not part of the Configuration object. It is not implemented.
There is a workaround that you can use the Configuration API. Let me show you with a small snippet of code:
string GetCameraDescription(VideoOS.Platform.Item camera)
var configAPI_camera = new VideoOS.Platform.ConfigurationItems.Camera(camera.FQID);
return configAPI_camera.Description;
