MIP SDK Milestone Kite compatibility
We have MIP SDK protocol integration implemented with Milestone XProtect. Is the current protocol integration compatible with Milestone Kite.
Milestone Kite has a REST API that might help you enable your integration scenario.
However, the Milestone Kite API isn’t directly compatible with MIP SDK Protocol Integration.
See the documentation for the Milestone Kite API here: https://msapi.arcules.com/docs.
Milestone Kite - Powered by Arcules®
Thank you very much, Rie
