How would I be able to stop Patrolling with the MIP SDK? From what I’ve read in other topics, it is possible to start patrolling with user defined events with XProtect expert or corporate version
In XProtect® Corporate and XProtect® Expert you can activate patrolling by using a little trick. From the MIP SDK, you can send a user-defined event. In XProtect Corporate you can use the event in a rule to start patrolling. In XProtect® Enterprise and streamlined products you cannot start the patrolling based on events, and that means that you cannot start the patrolling from the MIP SDK.
