Mobile Client - White Label / Integration
Hello. I work for a private security company and we have the Milestone XProtect solution installed as part of our surveillance infrastructura.
I am getting up to speed about Milestone Mobile Solution. Right now, we have propietary mobile application and I would like to know what the possibilities are of integration with our app.
I would like to see the camera footage (in the same way it’s being used in the Milestone app) directly in my propietary app. Is this possible? If yes, do you have API/SDK for this in order to integrate it?
Regards,
Pablo.
The Milestone Integration Platfomr Software development Kit (MIP SDK) includes documentation and a sample on how to integrate towards the Milestone Mobile Server. It is possibe for you to develop a moble app working twards the Mobile Server using this.
In the MIP Documentation (HTML) choose the protocl Integration area and in the lef hand side find
Mobile Server protocol
-Sample Request/Response
-Decoding frames
-Logon and Credentials
-Video Push
-Command Channel
-Video Channel
-Appendix
Look also at the samples: Mobile Server protocol sample and Mobile Playback protocol sample.
Thanks a lot. I was trying to download the Milestone MIP SDK 2016 10.0 but the link is not working, someone know if there is any problem or I am doing something wrong? I already filled in the form with all the information but when I press “Download MIP SDK 2016 10.0” it doesn’t work. It only says the page can’t be found. I don’t have proxy or firewall within my network. This is the link: **
This is not the link I get when I fill in the form (tested today). I cannot reveal the link as I fear it will be used to download without filling the form. Hope you understand. Please try over, start at..
https://www.milestonesys.com/community/developer-tools/sdk/download-sdk/
If you still do not succeed we must investigate deeper.
An alternative is to join as a Milestone Solution Partner. But download should be possible after filling the simple form in the page mentioned.. It would be interesting for us to know exactly how you found the worng link..
Now it Works! I don’t know what I did before. :S I will review the documentation and come back if I have more doubts. Thanks so much! Regards. Pablo Baustian.
