Mobile server service down
Mobile server goes down when user whants to see more than two cameras. All is allright whit just one camera.
We are using one server for Recording Server and Mobile server services. Phisical memori available is aporx. 40%. all time. CPU usage is aprox. 30 %.
This is an issue which could be caused by a memory leak issue, related to the driver for Intel QuickSync driver, which Milestone use for hardware accelerated transcoding in the Smart Client and Mobile Server. If this is the case, you will need to upgrade/downgrade the driver version.
The memory leak might be caused by an issue in the intel driver: "A memory leak has been observed while using encoding (h264) frames with the latest intel driver (15.40.25.4463). The current beta driver also has the memory leak (15.40.26.4474)
For more information, see https://software.intel.com/en-us/forums/intel-media-sdk/topic/670446.
Thakns Michael,
Now my problem is that Garphics card is a Integrated Matrox G200eH, 16MB video standard.
User facility has 3 servers runing Milestone XProtect Professional ver. 8.0c on Windows server 2012 R2.
Hardware: 2 HP Proliant DL120 G7 with 6 MB RAM and 1 Hp Proliant DL120 G9 8 MB. Each serversupport 50 camaras with H.264 encoding at 1MB resolution.
The original problem ocurred in server G9, Now another server G7 is droped Image Server Service.
I founded in Kwnolew base something related and indicated Virtual Memory issues.
Do you have more info about ?
