Module I/O
Good afternoon!
I have an AXIS P8221 I / O Audio Module, and would like to know if you could send me some tutorial or manual integration.
I have the Milestone Professional version +, and I need to do this integration in my network!
Awaiting return.
Since this is an audio module it might be a good idea to start with the audio samples in the MIP SDK if you want to develop a integration solution.
I might be able to give more guidance if you describe in more detail what you wish to develop.
If you need a more general guidance on how to add and use the device in XProtect I think you should ask in the Support Community. - https://force.milestonesys.com/support/MccSupportCommunity
Good evening!
I need to create alarm profiles to minimize the operation of electric fences, which protect the condominium that I work, I need the monitor can arm them and disarm them directly from the room monitoring and monitor their operation, if everything is ok.
Monitor whether they are turned on or off and send notifications when this happens, so the monitor can generate an action and check what happened.
Do you think you can do that?
When you create an alarm definition you have the following possibilities:
I believe this is what you need.
You might get more help from experienced partners who have set this up if you ask in the Support Community. So if you need further tips on how to use this I suggest you ask the Support Community.
