Could you please explain how the authentication works on the MIP SDK Samples? I believe we have security permissions blocking the code. The error is Exception in readXmlFile 401 Unauthorized when trying to obtain the token
Could you explain a bit more about when you get the exception? I would like to have specific steps so it is possible for me to reproduce.
I’ve run the Multi channel metadata provider sample and I’m the sample doesn’t login at any point. The sample is listening for a connection and then sends back metadata when the “Start all metadata” button is pressed.
Thanks for the response we have it working there was a proxy device blocking traffic on the network.
Get Outlook for iOS<https://aka.ms/o0ukef>
