MultiEnvironment Login failing
In release build the login to a server usually fails 3-4 times before succeding withouth giving any feedback exception.
The code i’m using is:
try
    var milestoneUri = new UriBuilder(ConnectionReference.Address).Uri;
    var userContext = MultiEnvironment.CreateSingleServerUserContext(false, Username, Password, true, milestoneUri);
    if (!MultiEnvironment.LoginUserContext(userContext, false, true))
      var milestoneEx = MultiEnvironment.GetLastException(userContext);
      if (milestoneEx != null)
        throw new InvalidOperationException($"Handler {ConnectionReference} - ConnectMilestone Fail", milestoneEx);
      else
        throw new InvalidOperationException($"Handler {ConnectionReference} - ConnectMilestone Fail");
    Logger.Debug($"Handler {ConnectionReference} - ConnectMilestone - Connected");
  catch (ServerNotFoundMIPException snfe)
    Logger.Error($"Handler {ConnectionReference} - ConnectMilestone - Server not found", snfe);
    userContext = null;
    milestoneUri = null;
    throw;
  catch (InvalidCredentialsMIPException ice)
    Logger.Error($"Handler {ConnectionReference} - ConnectMilestone - Invalid credentials", ice);
    userContext = null;
    throw;
  catch (Exception)
    userContext = null;
    throw;
When calling is empty GetLastException please look in the log files here [C:\ProgramData\Milestone\MIPSDK.](file:C:/ProgramData/Milestone/MIPSDK.) Hopefully they will explain what is going wrong.
Have you tested our sample “System Status Client Console” (https://github.com/milestonesys/mipsdk-samples-component/tree/main/SystemStatusClientConsole)? It uses MultiEnvironment and is a good way to verify that the basic communication with the server works.
