Not Receiving AlarmLine Object for AlarmForwardHandler NewAlarmIndication
I have an Event Server plugin that is registered to listen for the NewAlarmIndication event. The plugin receives Alarm objects but never received AlarmLine objects. Without the AlarmLine object plugin must perform an extra step to call Milestone XProtect to pull the alarm details using the Alarm objects included alarm id.
I would like to know what is needed by the plugin to also receive the AlarmLine object.
What the documentation says is that either an Alarm or an AlarmLine is sent on the event, not both.
https://doc.developer.milestonesys.com/html/index.html?base=miphelp/class_video_o_s_1_1_platform_1_1_messaging_1_1_message_id_1_1_server.html&tree=tree_search.html?search=newalarmindication
You will never receive both, if you receive an Alarm there will be no AlarmLine
How do I receive just the AlarmLine object? Being sent the Alarm object results in having to make a call to Milestone to obtain the details of the alarm that are needed.
I am a bit surprised by the question as the way I understand it the Alarm object, including EventHeader, should include more information than the AlarmLine object.
If you need the AlarmLine object you will have to make a call as you describe.
I have been thinking and I am really curious. Is there any information in the AlarmLine object that is not in the Alarm object? Could you tell me what field / object you are missing?
