I’m trying to set up the ONVIF Bridge on a Milestone Server (Corporate, v 2016 R3). I am reading the ONVIF Bridge Getting Started Guide (both 2016 R3 and 2017 R3), and some things are unclear to me.
- The Guide says, on page 7, “Milestone recommends that you create and add a dedicated user account for the Milestone ONVIF Bridge, and for each ONVIF client, as follows:”. Does that mean you need different credentials for the Bridge and each client, or that you only need 1 user/password that everybody uses? I can only get it to work if I use the same credentials everywhere.
- The Guide also says "In the Management Client, assign the user to a role that can access cameras, and specify permissions for the ONVIF Bridges security group on the Overall Security tab for the role. ". There are two problems here. First, the Guide is telling you to do this before ONVIF Bridge is installed. There is no ONVIF Bridge security group before ONVIF is installed! The second problem is that it is incredibly vague. Exactly what permissions do I need to set on the role? Don’t make us guess! So far, the only way I have been able to get it to work is to put the Bridge user in the Administrators group.
